Exhaust..
#26
fail.......
Originally Posted by willkrom1990
so is it pretty safe to say that i can't mess up the way the car runs by getting strait pipes all the way to the mufflers? i've heard so much controversey about it that i'm a bit nervous about getting that done.
also, with most test pipes, do you just have to make an inlet for the pipes that come in to the exhuast right about in the middle of the transmission area? i would imagine that i can drill a hole in the main pipe and weld a threaded fitting in there
#27
i'm going to have to find a write up on that. i've never even heard of that stuff. is there an easy bypass for it or does the elimination of the system require a new ECU? the car's not quite worth a new ECU. thanks agian for all the advise here. my car would probably be at the bottom of the river (intentionaly) without you guys.
#28
You can probably eliminate it without replacing the ECU. As long as you disconnect the sensor, it should work out just fine. There are writeups on AIV elimination all over the place, so it shouldn't be hard to find more info on it.
#29
alright thanks a lot. based on advise given here, i have decided to get test pipes made, eliminate the AIV system, and have my cat-back patched or replaced to eliminate the leaks. i'll let you all know how it turns out in a few weeks. i bet she'll be plenty loud then lol. its a bit too loud for me now!
#30
fail.......
noelawinslow
05-21-2013 01:17 AM
nismatic707
07-16-2002 12:51 AM
