Finding Gears
Guest
Posts: n/a
Finding Gears
I just bought a 93 na 2+2 last month. It had 73,000 miles on it so I took it to a mechinc and had the timing belt and some other stuff replaced, basically 60K mile maintance stuff done. He mentioned that there was a plastic piece that wears down on the shifter and he could replace it and it would be eaiser to shift gears then. Right now I do have trouble finding gears when I shift, it feels very loose compared to my friends 2002 extera. I am always able to find the gears on her car. He wants to charge $200-300 for labor and around $30 for the part. My question is A) Does this sound right, is there such a part that is plastic and wears down like this B) Is this something simple enough to DIY and are there any walk thur instructions for doing this anywhere.
Thanks
Thanks
Re: Finding Gears
Well, I wouldn't pay that much. On ebay I found bushings and a shifter boot for $35. The bushings are the #1 cause of shifter play and yes you can do it yourself.
1990 300zx NA (beautiful first year)
1980 Triumph Spitfire (last year)
Guest
Posts: n/a
Re: Finding Gears
I also just recently bought a '91 na coupe and my shifter is very loose. I can find the gears fine, but for example, if i'm in fifth gear the shifter can wiggle as if its in neutral. It doesnt come out of gear but has A LOT of play in each gear. Is this the bushings? Is it hard to change them or is it like changing the shift boot or something.
Guest
Posts: n/a
Re: Finding Gears
ZxJR,
In my search here is the best article I found explaining the task.
http://capitalzoftexas.com/archives/techtips/02/
Hope this helps.
Hope this helps.
Guest
Posts: n/a
Re: Finding Gears
this is a common problem with older Zs, and it's the shifter bushings. parts are around $30 like you said, but 200 for labor is outrageous. i payed $20 for labor for my guy to do it for me. www.ttzd.com and then click on tech. it's got all kinds of DIY things there. don't go to a mechanic for this one, it's an easy job and takes 30 minutes.
tom
03-11-2006 09:35 PM
