fuel injectors no power?
Old 01-08-2011 | 02:02 PM
hardenstine's Avatar
ok heres the deal ok. 2 of my fuel injectors where not ohm right so i replace them, but i decided to replace all of them with the newer ones like ever body says to do. so after a week of pulling and painting and rewiring and putting things back together i try to turn on the car and it wont cut on. so i look around and find the fuel injectors are not getting any power or continuity am i missing something here i cant find the fuse i think its next to the battery right? any way i been playing with this thing for a week in my free time so im taking a break tonight, maybe if im up to it i will look again. but am i missing something with the fuel injectors upgrades is th wiring backwards are something. any help or where to look would be great.
Old 01-08-2011 | 11:13 PM
domsgarage's Avatar
Tough Guy
how do you know youre not getting power to them?
Old 01-08-2011 | 11:20 PM
ohm meter not reading any power when key is on
Old 01-08-2011 | 11:21 PM
domsgarage's Avatar
Tough Guy
the key doesnt have to be on.
connect the cables to the part you spliced and see if it reads.
Old 01-08-2011 | 11:31 PM
just did im not getting no readings im going to look at it in the morning i most have forgotten to hock something up
Old 01-09-2011 | 10:38 AM
ok i hook up the ohm meter from the fuse box to the injector im getting a reading so i dont think its getting to the ground where does the wire go next?
Old 01-09-2011 | 12:45 PM
alright im getting power to the fuel injectors now the ground was not connect right but the car doesn't start i most have missed something
Old 01-09-2011 | 08:37 PM
domsgarage's Avatar
Tough Guy
did you kill the battery?
not starting how?
wont crank?
no power?
wont fire?
Old 01-09-2011 | 09:17 PM
no the car turns over but it wont click on. ok so i go out side and pull the CAS and 2 of the injectors are not clicking #1 and #4. scene these are the newer injectors #1 is stuck under the plenum and cant be pulled out with out removing it. fml im just going to remove it and grind that part down so it can be remove if i need to in the future its going to be another long week fml i need a drink
Old 01-29-2011 | 09:47 AM
domsgarage's Avatar
Tough Guy
Or you can remove the plenum and do the water pipe deletes this way it will only take like 15-20 minutes to get off next time you have an issue. It seems like the best idea considering all of the issues you have.
Solhaven
04-25-2013 08:30 AM
dan121
01-28-2012 11:31 AM
mwest300zx
01-08-2012 11:38 AM
ern
07-19-2010 09:58 AM
TeamRonin
10-06-2009 10:24 PM
Quick Reply: fuel injectors no power?
