fuel pressure??
Old 03-14-2006 | 10:19 PM
lowkeyz's Avatar
fuel pressure??
icon_super: wanted to up my fuel pressure on my car i installed a new exhaust and intake. my car is a n/a and was wonderin if anybody knew how many fuel pressure regulators to get it. It looks like this car has 2, one on each side of the fuel rails or do i need one and that controls the other?? also what is a good fuel prssure to run?
Old 03-15-2006 | 07:07 AM
CanyonCarver's Avatar
Jack Of All Trades
You have one fuel pressure regulator and one fuel damper. On your relatively stock engine, I wouldn't recommend increasing the fuel pressure. The amount of fuel injected into each cylinder is controlled by the ecu, the injector pulse width, and the pre-determined amount of pressure supplied to the injector. Increasing thr fuel pressure will cause more fuel to be injected during the injector pulse than the ecu is programmed for,
Just my $.02
Old 03-20-2006 | 05:05 AM
Mousier158's Avatar
Just my $.02
But increasing fuel pressure and get your ECU programmed for it and you will see gains. but as CC says dont do this to a ECU that is not programmed for it!
Old 03-20-2006 | 08:11 PM
91zxtt's Avatar
Increasing fuel pressure on a relatively stock car won't really do anything.
Old 03-20-2006 | 09:03 PM
jfairladyz's Avatar
It can cause a rich condition if the pressure is increased too much. It pushes more fuel past the injectors for the given amount of time they are open in comparison to having less pressure pushing the fuel through.
Old 04-19-2006 | 09:44 PM
lowkeyz's Avatar
thanx i planned on gettin a new ecu from ash-spec so i guess i will install that regulator
masterhufflpuff
03-31-2015 10:57 PM
Lupe
11-30-2011 09:15 PM
NewZMan
01-14-2008 08:28 PM
