fuel pump relay issues.
Old 10-05-2010 | 12:05 AM
ok, so the PO of my sisters TT killed the FPCU and hard wired the fuel pump to be at 100% whenever the ignition is on. No big deal, so I replace the two wires that where cut, plug a known working FPCU out of a q45 (same as the TT) and I got nothing. So I traced it down to the relay, everything works when I ground out the relay, so I go to the ECU pin for the relay and ground it out there and it works. Is there anything I could have missed that would cause it to not ground?
Old 10-05-2010 | 08:22 AM
skib's Avatar
This facepalm's for you!
sure Q45 is the same?
Old 10-05-2010 | 12:04 PM
I have cracked open 12 q45 FPCU's and they are the exact same, down to the coloring of the resistors.
wrenchwench
04-06-2015 04:27 PM
kbowden
07-14-2012 09:15 PM
LVZ280
08-08-2011 07:48 AM
hoov100
10-05-2010 12:05 AM
Loggerboy666
10-07-2003 01:43 AM
