gasoline smell
Old 09-17-2004 | 08:22 PM
b300z's Avatar
caught the z fever
gasoline smell
whenever i drive on a cold morning, i get a strong whiff of gasoline every now and again as i drive. it doesnt go away, until i get to school, which is about 4 miles or 15 minutes.
one of these days my gf and i are probably gonna die from inhaling that smell if i dont get that fixed.
anyways, any comments?
Old 09-18-2004 | 03:21 PM
Asian Twins's Avatar
You should not smell gasoline ever for any reason. If you do, you have a fuel leak and that means fire hazard. You need to go looking for fuel leaks.
Old 09-20-2004 | 06:48 AM
CanyonCarver's Avatar
Jack Of All Trades
This was on another forum........... Something to check out while you're hobbling
FPR vs. fuel dampener
I have a quick question. I'm getting a strong fuel smell from under my hood, and I've narrowed it down to the the little brass-colored arm thingy thats sort of tucked into the intake plenum on the upper right hand side. Is that the fuel pressure regulator, or the fuel dampener? After ooking at pictures of the FPR and FD, I'm a lil unsure.
Old 09-20-2004 | 09:56 AM
91zxtt's Avatar
b- thee cars have a tendency to develop fuel leaks when it gets cold. You do want to find them as ssoon as possible because it is a fire danger. Remove the plastic cover on top of the plenum. Follow the path of your fuel line from the fuel filter over the engine and tighten all hose clamps along the way. As your doing this, look for any areas that look wet. If you find any, focus your search there. May not be a bad idea to replace the fuel lines. It's easy and inexpensive. You can pick up fuel hose from any autoparts store.
Old 09-20-2004 | 01:00 PM
b300z's Avatar
caught the z fever
thanks guys. sounds good. i think im gonna get a dress up kit. get all new hoses and stuff, cuz i think i have a vaccum leak somewhere. theres a small whine when i turn off the car. lots of stuff to do...cant wait
Old 09-20-2004 | 02:19 PM
My Fairlady Z's Avatar
Ruined By Spudz
yah i took off the cover and looked and gas was just puddled between my plenums. It disgusted me...lol luckly i had some extra super duper fancy shmancy fuel line laying around the slice in the line looked like it was purposley done..but oh well
Old 09-20-2004 | 04:36 PM
Riz Z Speed's Avatar
Administrative Brown Guy
http://www.300zx.co.uk/cgi-bin/manua...fault&total=70
Fuel Pressure Regulator on the right. Fuel Dampner on the left.
bigp91z
13
11-20-2005 03:50 PM
91zxtt
01-31-2004 10:15 AM
robertpark
04-13-2003 04:51 PM
cookiecutter
12-10-2002 08:04 PM
funredz
05-31-2002 07:26 PM
