headlight aiming kit?
hey there, uhh, I just replaced all my speakers and when I had all the plastic pieces off the back of the car, right behind the drivers seat that one square-ish plastic piece had a little box with 4 black plastic pieces, I just saw the same things on ebay, and they said that these were a headlight aiming kit, does anyone know anything about this or how it works? i sorta need to adjust my headlights cause my left one is off a bit
Guest
Posts: n/a
Yeah, thats exactly what they are, and from what I have read about them on TT.net an autoshop uses them. I guess you cant actually do it yourself. Only what I have heard though, I'm not completly sure about that. Give your local autoshop a call and see what they have to say about adjusting them. Good Luck!
You can do it...
Actually, it's easier to adjust your lights the old fashion way. Just wait until its night time, pull up to a wall with your lights on and adjust the light up or down, left or right with the adjustment screws. Don't forget to do the high beams as well. If you have your owners manual there is a section in there that pertains to those tools although it doesn't show you how to use them.
o well, guess I'll just stick them in a closet or something, I would drive up to a wall but the closest one i can think of near my house would be an old winn dixie building about 7 min away, so I just adjusted them a bit in a best buy parkin lot, worked fine but they still need adjusting, o well, thanks for the info!
konahrtist
04-16-2006 11:28 PM
stealth300Z
05-10-2003 06:58 PM
240z, 300zx, adjusting, adjustment, aim, aiming, headlamp, headlight, headlights, instructions, kit, located, nissan, tool, z32
