help with auto trans
I need help. i have a 90 300zx tt its an automatic. When i shift in to D the trans goes in to 2nd, and wont shift up or down but i can make it **** in to 1st. and it wont go in to over drive
ermmmm.... wrong forum, you posted this in the 280ZX tech threads, not the 300ZX (Z32) tech. might wanna delete this one and post it where it should be otherwise, you wont get much help lol. and auto trans' are a bitch, might need some professional help, check the tranny fluid level first though. more than likely, if its not fluid, it wont be something you can diagnose by yourself unless your a really smart feller.
If everything doesnt work out a friend of mine got a new tranny off of ebay thinking it would be crap but he got it for a lil over 300 bucks and its lasted him a lil over 90,000 miles so far and it was an automatic 300z.
pft... u serious? my HS teachers if they required full sentences for work, or in english class in general, they were ****'s about that crap. thats why im so linient about it on here, because i dont get penelized for it. but i still keep it good so i dont get the problem of people not understanding WTF im saying.
just for quick on-topic ness since he never came back to his own thread and just incase
did you check the fluid level? only things i can think of is low fluid, something is actaully internally broken, the vein system is clogged but ATF is full of detergents so that shouldnt happen, or the TCM is goin out. either way, unless its just low fluid level, i doubt you can figure it out on your own since auto trannies are a PIA
I figured it out... I know EXACTLY what's wrong with it...
it's an automatic transmission in a GT car meant for a 5-speed.
But seriously, do as Eric said, check fluid level. Change it if possible before spending more money on expensive trans work.
i checked the fluid level. It was over full i pulled down the pan and, found plastic in the pan. along with a lot of metal shavings. The trans oil looks like candy apple paint i think the trans is taken a ****..
there was a big piece of plastic in the trans pan i took it to a trans shop they said they but the scanner on it and they say its some thin wrong with the trans. any one have the same problems or know where i can get a trans.
