Help with Fuel injector upgrade
dude u are gonna have to pull off the top splatic part then looks down to figure out what all u need to remove to get down to your fuel injectors.. start with the your fuel filter first hint hint .. your gonna need sockets with extenions... good luck yo...
http://twinturbo.net/net/viewmsg.asp...&msg_id=970094
You can get all of the injectors out with the dremel method. You only need a phillips head screwdriver to get the injector screws off. Afterwards, replace those screws with socket head cap screws.
We shall aSSume that you know you need new injectors, but are clueless about how to replace them.
I just realized the title of this thread is about injector upgrades. I would just pull you whole plenum. Here's a write up.
http://twinturbo.net/net/viewmsg.asp...&msg_id=880107
last time i checked, you need to a remapped fuel curve for upgraded(larger) injectors, I.E. new ECU.
so don't just go throwing new injectors in that aren't the same size without first addressing the fuel issue.
by the way, guys, you can do all six injectors without pulling the plenum or shaving away at any of the metal that Nissan put there. Get 45 degree angled mini vice grips to get the screws you can't reach. I knew a guy who could do all six with this method in about an hour and a half.
GrayHairSleeper
05-20-2015 06:24 PM
