Hicas/Abs light on!!!
Old 11-10-2005 | 08:22 PM
oldschool's Avatar
This morning my Hicas light turned on and I was slighty loosing power steering. I was going around 65mph when it happend. My Abs light turned on also when I hit the brake hard. When I got home I check the Hicas fluid resevoir and it was full. I turned off the car and turned it back on. Eeverything went back to normal power steering and Abs light never came back on. What can I do to fix this problem!!!!
P.S. I have a 1990 300ZXTT
Old 11-10-2005 | 09:34 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
How's your speedometer working? Since the HICAS is speed sensative, a bad speed sensor could cause a condition like that if it's occuring at a certain speed (that's the cause in my case).
I'd say it could be a bad HICAS system, but in my entirely Z life (and in my entire career at Ultimate Z) I only ever even heard of 1 HICAS system failing and it was on a 96.
do this
http://www.ttzd.com/tech/hicastech.html
Old 11-10-2005 | 10:24 PM
oldschool's Avatar
The Hicas ligt started to come on after the ABS light came on. When I got home from a 45 min. drive I turned off the car and turn it back on the system is back to normal again. The power steering is working properly.
Old 11-10-2005 | 10:52 PM
if it's in conjunction with the ABS light, I know EXACTLY what it is... it's a fuse.
http://www.twinturbo.net/net/viewmsg...&msg_id=950732
Old 11-11-2005 | 07:04 PM
oldschool's Avatar
Thanks man!!
Dirt Winston
03-26-2013 09:26 AM
joel280zt
08-02-2012 07:10 AM
Rupe
12-04-2011 12:28 PM
ricky0288
05-27-2011 11:07 PM
300zxBoi
05-08-2003 12:04 AM
