Hicas eliminator
Hicas eliminator
I was looking all over the Z forums and I can't find any write up for installing the Hicas eliminator. How do you exactly install this? Do you just disconnect the Hicas system and install the eliminator kit? I have read some old post that you have to change the TT pump to NA and plugs some of the holes. I seems like there are more things that needed to be done and purchase when installing the Hicas Eliminator kit. Any advice would help!!!!
You only need to change the pump, lines, brackets, pully, etc out to NA equipemnt when you are completely removing the system from the car. That means taking out the equipment in the front of the engine bay on the fender.
I'd suggest you change the whole subframe from the TT to N/A. I changed mine and it made a worlds of difference, but I'm not sure if it was the solid sub frame or the fact I installed a bushing kit at the same time, But for me it felt more solid.
