I Have A Problem!!!
I Have A Problem!!!
Ok, ok, yes, the first step is admitting it. LoL
Ok here's the skinny, My 1990 M/T N/A z32 fairlady dies after coming down from high rpm's.
If i ride like a good boy it's fine, but if i ride like a fat kid to the ice cream store, it hates me for some reason.
If i take off and shift at 3.5 rpm or more in each gear and push the clutch in or pull into neutral from 3rd, 4th, or 5th gear it will drop rpm to 2-3 hundred and die on me. I can rev up to save it but it's hard to brake for a light and rev up at the same time.
Queen of Yachts
Location: warmspott, trollville.......somewhere sailing the seas--fla, virgin islands...wherever....warm water....LOL
heel /toe funnn---worse gets the problem, the more funner you'll find it--there are so many reasons why your car is doing that--i know-- my AE had ALL of 'em--but it is wonderfullll now
Do you happen to have a pop charger or other cone-style intake on this car?
In most instances where this happens, it's a combination of a cone style intake and the IACV being set too low.
Search though... I instructed someone on how to adjust their idle and resolve the cone-style intakes not 2 months ago.
haha heel toe...soo easy....jsut learn to rev match while your at it...screw a clutch. and yeah...run codes, zlover is smart so reply if you have a intake like he said. he can throw up a write up on it or something. and if it was a vacumme leak wouldnt it hardly idle then to jsut after start up? not after letting off the gas? sounds almost like turbo cars when your boosting and just let off and it chokes it from teh mixture being to rich...but its not turbo, i just felt liek throwin that up there.
yea, I was gonna ask if you had a popcharger and not a splash shield. There's a duct tape trick if that's your problem, but I recommend just getting a new splash shield. Stalling after high revving with a popcharger is common. If not, an air leak or something electronic (run your codes like stated before).
... sounds almost like turbo cars when your boosting and just let off and it chokes it from teh mixture being to rich...but its not turbo, i just felt liek throwin that up there.
By the way, all you people saying "heel-toe"... that's a bandaid fix. A healthy car should be able to resist stalling when coming down from speed. Sh*t, if your car wouldn't idle, would you just keep your foot on the accelerator or would you get it fixed? My philosophy... resolve the problem or buy a car that is more reliable. Bypassing the problem is for poor people... poor people should not be driving a 300ZX - they aren't exactly cheap to maintain.
did you really think i was serious about that?
I hope you didn't take offense to it though.
haha 4 cylinders...and yeah i forgot it was with BOV's....i knew...but fogot...had no clue the afc could do that though thats cool and very nifty......ill remember that if i ever make it around to gettin me a turbo car... i want car....
Two new symptoms
It now smells bad of gas when i stomp it. and if a cruise in any gear and only press the peddle a little it jumps and stalls like its choking for air or fuel.
My boss sais that that's a common symptom of a bad fuel pressure regulator and im inclined to agree with him seeing as my old z32 had the same problem and a tech pinned it down to that.
RUN CODES !! WWW.TTZD.COm can help u out more then we can.. " eaze out on the clutch ? " aka ride the clutch "
