Idle Air adjustment Screw
#26
oh my fualt, i definitly did not read that enough, there's a yellow plug connecter to the aac valve. the plug is on the iaa unit toward next to the firewall, it's held in by a wire clip. unhook that first then adjust the idle. you can turn the screw clockwise slowly and see what happens.
Here's it easier... in order
with car idle, unplug yellow connector
turn idle adjustment screw to set base idle
counter clockwise to increase idle
clockwise to decrease idle
plug in the yellow connector, idle should shoot up about 500 rpm to indicate the ECU is taking over idle control
I don't know if this helps but this is all i know it =)
83Zturbo
07-08-2009 08:26 AM
kiboy6
12-13-2008 02:53 AM
Spurs212095
08-09-2007 07:29 AM
vvillium3
03-01-2005 08:37 PM
