Igot a 1990 300zx N/a !!!
Hey every body i just picked up a 1990 7th month of 1989 300zx n/a with a auto tranny this ones a 2 seater yaa!!!1 but the real questions are this i paid about 2500 dollars for this car stock did i get a good deal ? but i think there is a valve knock on the top why im saying this is when i stat up the car in the cold u can hear it knock ping etc pretty bad i had a few extra friends give me some of there advice and there saying sticking valve or bad valve springs.. also since i got this 1990 i remeber there was a web site that had a tranny check mod.. somthing like puting hte car threw the gear an pressing the brake pedals with the car in engine start mod but not started.. any help ? oh yeam ore questions does any body know is the twin turbo test pipes sold on ebay will be the same on the 2 seater non turbo ? any body with used test pipes? used HKS or Somthing like that Exhaust ? does the 1990 300zx have the ABS accuwatter in the rear trunk area? why my brake light is on ? .. anyt one let me know thanks ,ken
1982 280zx turbo 2+2 blue on blue manual tranny
1993 300zx n/a/ 2+2 white on black leather auto tranny
1990 300zx n/a/ 2 seater white with grey interior
Jack the car up and if the sound is louder under the engine..then its your rod.
if its the hydrolic valve lifters, its nothing to worry about there is a spring behind the cam gears and if the spring isnt installed correctly or if its just missing it will knock or click.
yeah i have a 1990 N/A too. btu I still don;t knwo wtf ure talking about. that taping noise might be that ure due for an oil change. mine use to do that. put in some MObil 1 10-W40 fixed mah problme right up. (Along with OEM nissan oil Filter)
Originally Posted by oakleyp2
i picked up my 90 300zx na 2+2 for $3200. the suprising thing is that everyting works! Car is in pretty darn good shape.
well every one im taking the 1990 300zx into the shop tomorow i will keep every one posted on whats going on with it.. so far i have done a Castrol Full sysentec oil change 10-30 k&N oil filter , put in 80w 95w rear diff oil, that stuff is rank i could still smell it a mile away !!!! i was told my 1990 has the VIS LIMITED SLIP DIFF ? should i be impressed? umm when i have more time i will be droping the tranny pan and doing the tranny filter and tranny oil, any one know how to do the ECU CHECK ?
Ok i took the car into the nissan car dealership to have then diaognois this littel problem i have they said the timing belt is so worn that its really slipping and hitting the timing cover? i havent had any time to check thius out my self.. is there a place were i can install the new timing cover and news tensionors myself? im gonna snap !!! if i have to pay 600 dollars to have a new timing belt put on.. any help yall ? any good links with pictureS? helps etc?
if you're asking for parts, check with courtesy or at ocncept Z performance. I believe Rizz's link page can help you out as well. As far as how to do it.....here...
http://www.ttzd.com/tech/timingbelttech.html
I'm gonna go out on a limb here and say the you do not possess a thorough understanding of how an internal combustion engine works. I'm alos going to bet that you don't really know the side-effects of installing a timing belt incorrectly. If my assumptions are correct, then just have the dealership do it. If the timing belt is actually hitting the inside of the ttiming cover, then I suggest you have this done immediately. Replacing the timing belt is a 4 hour job. $600 isn't bad for having the dealership, if they do it right and replace the belt, tensioner, pulleys, cam seals, main seal and VTC springs.
Not to mention if there's further problems, you can take it back to them and have them fix it cuz they screwed it up.
and calm down, no need for you or the timing belt to snap. Just take care of it.
Ok people the 1990 is in the SHOP !!! i will find out in a few days whats wrong and whats not wrong but for sure the new timing belt is being put on , plus i talked them down to 450 dollars i dont have a hole lot of money to spend , darn i wish i had more time off from work then i would install the timing belt my self, and for all u people who think ( im some dumb *** ) i do work on my own cars my self ( you can only learn from working on them )
1982 280zxt 2+2
1993 300zx 2+2
1990 300zx 2 seater
1982 280zxt 2+2
1993 300zx 2+2
1990 300zx 2 seater
