infamous highbeams
infamous highbeams
hey guys need some help my highbeams are stuck on no dash lights or taillights till ibrake ireplaced the switch and illuminated fuse any ideas plz i kno people talk alot about this but never hear how to fix im goin crazy
Some one plz! I know this topic gets old but im at a loss here idk wat else it could be fuses are fine order a new turn signal switch but still don't think that it pulled the passenger fender to look for shorts any one plz!
Just the highbeams I've checked fuses,relays,changed my switch haven't found any messed up wires I tested the pink/black and pink and have power to them but no power to the red/blue wire and idk why its driving me crazy
I can almost guarentee that your problem is your TCU(Time Control Unit). It's located underneath the steering column on the side where your left foot would sit. What I mean is, sit in your car, and move your left foot left until you hit the side. That's where your TCU is located. Pull that off, and it's a white box.
I had this same problem and took it apart, turned out that there was a burned out line on the circuit board, and I just soldered a wire in it's place instead.
The Closer
13
01-26-2008 08:10 PM
