injector cap broke
Old 04-04-2010 | 06:12 PM
Lanoi's Avatar
injector cap broke
i was putting new seals for the injectors mine were shredd and riped up and i set the injectors on the table and one injector tip which is like plastic cracked . How bad is somthing like this ?
Old 04-04-2010 | 06:22 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
It's not the end of the world... it might cause the injector to come loose if the engine is running rough, but most Z32 owners have experienced broken injector clips and dealt with it until the injector went bad.
Old 04-04-2010 | 06:30 PM
Lanoi's Avatar
so the plastic tip of the injector just helps hold it in ? i think ive read in thesse forums that my style injectors (90-93 mine being 93) are common to breaking. so i should just put the injectors back in and wait for then to fail and replace. even with it being crack is fine
Old 04-04-2010 | 06:32 PM
KasbeKZ's Avatar
Pr0n Addict
i'm selling a set of 5 low mileage old style n/a injectors pretty cheap. installed in rails with new o-rings. hit me up. no broken tips.
Old 04-04-2010 | 06:39 PM
My mistake, I thought you were referring to the connector plastic being broken. The plastic cap being broken isn't the end of the world, either, though.
Old 04-04-2010 | 06:58 PM
Lanoi's Avatar
k when mine start to go ill pm u
Old 04-04-2010 | 07:00 PM
Lanoi's Avatar
i should have my z running again tom or tuesday. thanks for the help u two have given me with my rebuild. ill keep posting if ya care how i fair my my start up. hopefully it doesnt take a dump after a day or even few hours of running lol
Brotha_Z
01-27-2014 04:25 PM
DavidMulligan
12-17-2012 12:25 PM
KasbeKZ
33
11-07-2007 05:24 PM
thxone
05-24-2006 12:09 PM
espi
01-31-2006 06:11 PM
Quick Reply: injector cap broke
