intake sensor mod on ebay
Old 10-22-2002 | 12:30 PM
Re: intake sensor mod on ebay
It has something to do with either modifying the signal of the air temperature or head temp sensor. They are usually a "volume" control that regulates olhms passing through a wire. The "volume" **** is the adjuster. It will richen or lean your fuel mixture. Possibly adding 5-10 horsepower to a well modified n/a engine. No way could it add 20hp unless you are running a turbo charged engine and your computer is not working right to give you the proper fuel mixture. Its a 2-dollar Radio Shack item, and basically a scam. You can make one yourself if you are curious.
I heard of someone doing that to the head temp sensor on an n/a 280zx, and it sorta worked. Maybe added a couple pounds of torque. Just barely enough to notice. It also decreases your milage when activated.
DocBombay
11-28-2006 09:09 PM
stinky
FS: 300ZX (84-89)
11-15-2005 01:59 PM
KTM200-280zxt
05-25-2005 06:28 PM
carloz
FS: 300ZX (90-96)
01-31-2005 01:38 AM
lightspeed
10-21-2004 01:57 PM
