Loss of power, hesitant acceleration
Old 07-06-2011 | 09:48 PM
Salazee's Avatar
Hoping for yours guys help. I have a 94 n/a and recently began to have trouble. There is a significant loss of power even when I floor it, it barely accelerates. The engine also makes like a clicking or rattling noise. I've replaced the fuel filter and spark plugs but no luck....
Old 07-06-2011 | 10:30 PM
Welcome to ZDriver!
Have you pulled the ecu diagnostic codes?
Old 07-06-2011 | 10:33 PM
Salazee's Avatar
I did and got code 55 which didnt help
Old 07-12-2011 | 02:20 AM
HexaggramJDM's Avatar
check timing, if its incorrect, correct it. If it is correct, it can be a malfunctioning ECU.
Old 07-12-2011 | 02:40 AM
Salazee's Avatar
Thanks for the tip!!
Im an amateur mechanic at best so do i need a timing light? n the ecu is ok cuz i swapped it out with an old one to check...i am goin to check tomorrow to see if the knock sensor is functioning..
Old 07-12-2011 | 02:45 AM
Salazee's Avatar
i forgot to mention that when the car is stopped the idle falls to almost 0 and sometimes stalls but it usually goes back up to 1000...it keeps doing that until you start accelerating
Old 07-12-2011 | 07:26 AM
ls1angela's Avatar
try to pull your MAF sensor off and clean it .
Old 07-12-2011 | 10:30 AM
Salazee's Avatar
i cleaned it with an maf cleaner from the auto parts store but no luck....i actually ordered a new one last week so hopefully it will work
Old 07-12-2011 | 07:04 PM
Salazee's Avatar
tried the new maf and still nothing...took it to the dealer and they said its probably a problem with the wiring harness and it costs 600 just to diagnose and they rather not even do it cuz it could open up a can of worms...
Old 07-13-2011 | 04:27 AM
how long has it been since your timing belt replacement??? if anything it skipped a beat, and the clicking/rattling could be an idle bearing or the tensioner, it could even be a valve. im just assuming since you get a code 55. Also check for vacuum/Boost leaks.
Old 07-13-2011 | 03:20 PM
ls1angela's Avatar
make sure all pipes and hoses from MAF to throttle body are connected and good condition (no rips ) . code 55 indicates there is no code stored . timing belt alignment is also a good place to check , but it is very time consuming . good luck .
Old 07-17-2011 | 12:02 AM
Salazee's Avatar
Every time I retrieve the codes now I get a different one..13 33 34 42 53...I never get the same code twice in a row. I plan to take it to z spe******t if there is one in socal.
Old 07-31-2011 | 12:03 PM
Salazee's Avatar
turns out it was the timing belt. i chekced it out and it was off by 4 teeth. luckily no bent valves. thanks for everyones help and thanks hexaggram for pinpointing it.
Fozy
03-28-2011 08:42 PM
mikesz
05-29-2008 12:06 PM
Cw2435
350Z Performance / Technical
14
02-22-2004 11:33 PM
Cw2435
01-18-2004 06:29 AM
280zdriver_16
01-09-2004 11:39 AM
