Lurch when A/T shifts from first to second gear
Guest
Posts: n/a
I have a 1990 N/A 2+2 that lurches from first gear to second gear when the engine is cold. After driving for a few minutes, it goes away. I've been to a couple of transmission shops and they say there is no adjustment for this condition and that my transmission probably need to be rebuild. Any ideas?
I have had issues similar to that with my transmission, one thing that fixed alot is that it turned out a bushing was cracked around where the pedal actuates the slave and so not allowing full release of the clutch, although this may sound obvious it was not obvious at all that somthing like that would be causing the problem, so check everything out... i think the bushing was like $1.75 from nissan.
Guest
Posts: n/a
Originally Posted by OrangeZ32
the 300's auto trannys are crap, there is a good chance you might end up scrapping it. How many miles are on your Z?
it's tough for me to justify spending 3-4k to have the trans rebuilt when my car blue books at about 6-7k, and while it does have a lurch.. oddly enough it goes away after the car warms up.. i want to add some cheap performance upgrades but again i don't wanna drop thousands of dollars in the car, especially considering my lack of trust in transmission shops and the doubletalk i get from my local nissan dealership.
i have two problems: the lurch as i mentioned and slop in steering at speed. if i could get these two problems resolved i'd be really happy with my z because it's in great shape on the exterior, interior, and has super low miles for a 15yo car. any advice is greatly appreciated!
Guest
Posts: n/a
by the way, i should also mention that i have replaced the faulty bose stereo with an aftermarket system including a powered subwoofer in the back. i have read a couple of threads that say my lack of power and/or lurching could be due to battery/alternator not being able to handle the additional requirements placed on it by the stereo. it has been recommended that a grounding kit might resolve my problem. is this likely?
KENZ
08-19-2005 12:13 AM
