Mod updates
Old 02-11-2005 | 10:26 PM
  #51
bardabe's Avatar
Bad Speller
DUDE!!!! Good luck so really can I go down there it's only liek a 2 hour drive 3 tops. and hell I'm trying to offer my cervices and learn a thing or 2. it's ok if I get hit with the hammer or torche. my brother and I have both taken hit's pretty abd since we both loose our temper and take it out on each other. so dude I wanna go down there man. I really wanna see your Z. maby help you out here and there. but mostly to learn and help you out dude. I can't make it this weekend cause I'm workign but next week count me in (if ure cool with it)
Old 02-11-2005 | 11:00 PM
  #52
Zgringo's Avatar
El Viejo
I don't feel so bad now with all my scared knuckes, fingernails broken till they bleed, dents in the walls from throwing tools, only to be so pissed I was ready to burn the car, go in the house, come out 5 minutes later only to have what was pissing me off so bad fall in place. Damn it's fun, I love it. Just make sure there's a socket set in my coffen when I die. Might need them on the other side.
Old 02-12-2005 | 05:06 AM
  #53
CanyonCarver's Avatar
Jack Of All Trades
Originally Posted by Zgringo
........ come out 5 minutes later only to have what was pissing me off so bad fall in place.
Man, don't we know that so well.
Bardabeeeee, yahoo maps shows the following, "Distance: 554.9 miles Approximate Travel Time: 8 hours 32 mins" and if you drift your way there it'll take a little longer. But then again, maybe 91 needs help with that garbage disposal this weekend.
Old 02-12-2005 | 07:40 AM
  #54
bardabe's Avatar
Bad Speller
ok.... uhhh did U move or something? last time I looked it was only 3hours. btu oh well. hell I'll still go. I'm down I'll go. and yeah I'm a pro garbage disposer.
Old 02-13-2005 | 08:41 AM
  #55
91zxtt's Avatar
Nope, haven't moved. Maybe you have CC and I confused. He had offered to help you with your t-belt when he was chanigin his. How far is it from Acton to Riverside?
Fixed the broken pipe. The disposal is in and fundtional. 1st try on both!!!!! Woohoo!!! Digging a trench sucks.
Didn't get to the Z yesterday, bt I'm off to Kragen in a few minutes to get the hose and clamps I need for the coolant bypass hose bypass.
Old 02-19-2005 | 06:25 PM
  #56
91zxtt's Avatar
Made some good progress today.
Old 02-19-2005 | 06:48 PM
  #57
ZXDude90's Avatar
Aqua Teen Hunger Force Fan
Keep up the good work 91. I bet that polished upper plenum will look great when you get it on.
Old 02-21-2005 | 06:18 AM
  #58
Jack Of All Trades
So what's the picture of the tube? egr?
Old 02-21-2005 | 08:57 PM
  #59
91zxtt's Avatar
Yep. I posted some other photos of them on here somewhere. They were really clogged before.
Old 02-27-2005 | 08:34 AM
  #60
91zxtt's Avatar
Ow, my hands hurt.
It took Dad and I about 2 hours just to get the EGR valve mounted onto the back of the intake manifold. The 2 bolts that hold the EGR valve on are completely unnecessary. If someone wanted to, they could just bolt a rubber plate to the back of the manifold to keep the EGR valve from vibrating against the manifold. The EGR is held in place in 6 locations (1 - feedpipe from exhaust, 2 & 3 - EGR tube brackets at rear of engine between intake and exhaust cam covers, 4 & 5 - EGR return lines bolted to underside of upper plenum and 6 - bolted to back of intake manifold). See my point. Oh well, at least it's in. Back to work.
Old 02-27-2005 | 05:37 PM
  #61
b300z's Avatar
caught the z fever
you should have just cut it out and called it a day
Old 02-27-2005 | 08:39 PM
  #62
91zxtt's Avatar
If I didn't live in Cali, I would've. I re-connected the heater hoses and got the coolant bypass completed today. I was going to get my intercooler piping installed, but I need to replace the 3" rubber coupler at the turbo outlet, so I have to order it. Maybe next weekend.
Attached Thumbnails Mod updates-21.jpg   Mod updates-22.jpg   Mod updates-24.jpg
Old 02-27-2005 | 08:46 PM
  #63
ZXDude90's Avatar
It's coming along . How hard was the coolant bypass?
Old 02-27-2005 | 08:51 PM
  #64
91zxtt's Avatar
The coolant bypass was easy. The plenum removal was the b*tch. I would estimate that the bypass removal eliminates 8 of the bypass hoses that run under the plenum. It's a much cleaner setup. I'm sure that the coolant will circulate with less restriction now.
Old 03-06-2005 | 07:12 PM
  #65
91zxtt's Avatar
I can almost see the light at the end of the tunnel.
Nothing else should be extremely difficult to put together, just time consuming.
Attached Thumbnails Mod updates-picture-010.jpg   Mod updates-picture-011.jpg   Mod updates-picture-012.jpg
Old 03-06-2005 | 07:45 PM
  #66
bardabe's Avatar
Bad Speller
I think I'm gonna cry. it's so so so.... beauty full nice goign keep it up 91. i just gotta have some sound clips and videos's when she's done.
Old 03-06-2005 | 09:30 PM
  #67
Jack Of All Trades
Thaz lookin good. Can't wait to see the plenum on there.
Old 03-07-2005 | 06:08 PM
  #68
Riz Z Speed's Avatar
Administrative Brown Guy
hey 91zxtt,
you gonna leave the cam covers stock black?
just wondering.
looking real good btw
Old 03-07-2005 | 08:17 PM
  #69
91zxtt's Avatar
Yes, I'm keeping them black. I figure if I painted them they'd look like crap in a couple years and I'll have to redo it. I may paint them at my next 60k service. That way I'll have the back plate off as well and I can paint that also.
Old 03-10-2005 | 03:56 PM
  #70
Zgringo's Avatar
El Viejo
Damn 91zxtt, I just might have to come up there and have you detail my engines.....Looking good, real good.
Old 03-13-2005 | 09:45 PM
  #71
91zxtt's Avatar
More progress...
Attached Thumbnails Mod updates-re-assembly-11.jpg   Mod updates-re-assembly-12.jpg
Old 03-13-2005 | 09:49 PM
  #72
Zgringo's Avatar
El Viejo
Looking good,,,,your getting closer....might just have to come up and have a looksee when your done.
Old 03-13-2005 | 10:53 PM
  #73
bardabe's Avatar
Bad Speller
I think I might go To see it fire up and record the firstrubber inprints on teh street
Old 03-14-2005 | 11:56 AM
  #74
SHWAZ300's Avatar
How can you guys and gals come up and see each other, do u all live in california???? If so that sucks for me lol, i live in PA. Well Philly aint too bad.
Old 03-14-2005 | 08:40 PM
  #75
91zxtt's Avatar
A few of us do live in Cali, but it's a big state. It's not like we're all neighbors.
Quick Reply: Mod updates
