NA UD Pulleys
Guest
Posts: n/a
NA UD Pulleys
'93 NA ZX (90K): Recently, I opened the hood and noticed that my Z decided to discard its AC Belt. The local dealer said the AC pulley was bad, but the Compressor was OK. I can live w/o AC, I plan to have the T-tops out as much as possible.
I'd love to install UR underdrive pulleys but $500 + belts is steep. Auto Specialties has what I assume is only the main pulley for $120. Is there another alternative, and/or if I leave the AC belt off will I damage the A/C compressor and cause an unbalanced loading on the engine due to no belt on one side? Any info is appreciated, Thanks
Guest
Posts: n/a
Re: NA UD Pulleys
i recommend the UR pulley because it is a more well known company and i have it and all my friends have it, NO PROBLEMS.
email Kyle@strictlyz.com you ONLY want the crank pulley...you do not want the other lightend ones, otherwise it makes the crank one work harder again...totally defeating the purpose of the LIGHTEND crank pulley...so DO NOT BUY the set. buy the UR one for about 200 shipped...email kyle, he can get them.
the AC pulley is about 90 bucks i would assume.
"Sometimes I Feel I Have to Compete With Your Car"
