need advice!
Probably the clock spring in the steering wheel. Do some searching - I've never replaced or diagnosed one on a Z32 (my Blazer's airbag light frequently comes on, and I know it's the clock spring).
Airbag systems are very sensitive. If any one module malfunctions, the airbag light will illuminate. A usual culprit for many cars is the passenger seat occupancy sensor. In your case, I'm not sure what a flashing light means though. Any info in the FSM? Maybe you could get your hands on an air bag scanner tool?
"Flashing" suggests a constant on-off-on-off-on-off at a consistent rate. Now, is it flashing, or does it come on intermittently (RANDOMLY on and off, at a non-consistent rate... just comes on and goes off sometimes).
