need help piston wall???
Guest
Posts: n/a
i bought a 1990 twin turbo with what i was told to be a bent valve and tore the heads off and the piston is melted throught to the oil pan and the valves were melted closed but the main problem is the piston wall is really scared.
what are my options?
can i bore it out and put a sleeve to make stock size?
can i bore it and add oversized rings?
i really need to find out thanks
WanganDevilZ
09-23-2012 09:06 AM
