nitrous
Guest
Posts: n/a
Re: nitrous
I will let you know in about 2weeks. I have a 90NA that I am waiting to install the N2O in. I had to order it from the US and am waiting for it to arrive through customs. That was all I had planned to run was a 50shot so I did not burn up my engine. Everything that I have read with the exception of a couple people say that when installed corrected and used responsibly a good engine will have no problems. On the other hand any time you pump more power through a device the life span gets shorter so no matter how you slice it, adding turbos, exhaust or any other performance enhancing 'thing' will add wear to your car.
..Dan
..Dan
