no throttle response
Hum... a good attitude like that will sure get you the help you need...
check out www.twinturbo.net You might fit in better there.
Maybe you could also start with mechanic basics. Like... check the ECU codes, check the sensors, check the spark plugs, check the compression, etc.
A basic ideal would be if the throttle cable is working that he has the throttle cable on the Cruise control part (left side) not the throttle control itself on the right facing the engine.
Second, if it's not that,, your throttle bodies could be stuck.
But, most of all there is VERY little information given to help solve the problem
he said he was moving the throttle bodies by hand.
anyway, you've just gone through and answered a bunch of threads from months ago, who's writters have moved on and don't check frequently any more. you might want to check the dates on the threads you're responding to
Mr1300
05-13-2011 01:33 PM
