Noise coming from dome light
Old 09-15-2003 | 04:09 PM
lifegrddude's Avatar
Externally Wastegated
Not sure about the dome light noise, but it may be coming from your engine bay due to a loose fan belt. Pop the hood and check it out while a friend revs the motor a bit. Other than that, I don't know what else to say. Maybe a bad ground somewhere like when speakers make that whining noise?
John 82ZXT
Old 09-16-2003 | 10:58 PM
I don't own a 300 like you do, but if it's that fan that's making the noise, maybe it needs to be lubed. Check with a Haynes or Chiltons manual on how to access it to see if that's all it needs.
John 82ZXT
Old 09-17-2003 | 11:43 PM
300zxBoi's Avatar
I had the very same problem. And it was the fan in the light that calculates the climate of the car. I Poped the light off and i took out the fan. You can try your best to lube it or whatever but it doesent hurt to stick somethin in there so the fan doesent rotate.
Old 09-20-2003 | 01:31 PM
maxp's Avatar
http://www.twinturbo.net/ttnetfaq/FAQpages/tempfan.html
http://www.aus300zxclub.com/tech/acfan.htm
Old 09-22-2003 | 06:58 AM
tsefreeflow's Avatar
I'm Chillin
You cannot get a Haynes or Chilton manual for the Z32s, they were never made. You can get a manual on CD thought off of ebay or Courtesy-Nissan.
jti30666
05-21-2012 03:18 PM
SoulAmazing
05-18-2011 02:41 PM
njgheewala
06-17-2009 11:56 AM
GeeYawn 280zx
01-25-2004 06:51 PM
1tuffz
09-15-2001 05:10 AM
