Noobie Clutch Question
Old 06-08-2005 | 08:53 PM
Z_TankIsFull's Avatar
We Don't Need No Stinkin' Fuel Economy!
Hey Guys I have a 1990 z32 and I have a clutch problem I just replaced the Master and slave cylinders for the clutch and when I bleed them the pedal doesn't gain any pressure at all but there is no leak in the system and everything is hooked up. Also the fluid flows like it's suppose to in other words there's no blockage in the system either the only thing I can see that might be wrong is the lever for the throwout bearing doesn't move while the pedal is being pumped but that wouldn't have anything to do with it not building pressure would it? I am truly stuck and am in need of asistance thanks
Z_TankIsFull
Old 06-08-2005 | 09:03 PM
Fast240Z's Avatar
make sure that the rod that connects from the master cylinder to the clutch pedal is the same length. When I swapped my master cylinder, the new rod was shorter, and prevented the pedal from getting proper throw. I'd check that first.
Old 06-08-2005 | 10:40 PM
Riz Z Speed's Avatar
Administrative Brown Guy
don't forget that there's a second bleed point other than the one by the slave.
On the passenger side in the engine compartment, behind the power steering reservoir is another bleeder.
Old 06-08-2005 | 11:18 PM
bardabe's Avatar
Bad Speller
don;t forget to get speed bleeders. makes the entire job alot easier.
Old 06-09-2005 | 08:54 PM
I know exactly which one your talking about I saw it yesterday and thought it was for somthing else Now my question is which do I bleed first the slave or the second bleeder or does it matter thanks again guys for all the help
Z_TankIsFull
Old 06-09-2005 | 10:05 PM
bardabe's Avatar
Bad Speller
I bleeded the top one firstthen the one in teh slave. i followed the brake bleeding instruction start with the one furthest from the master cylinder.
Old 06-10-2005 | 06:45 AM
topless93's Avatar
Accodring to the Factory Service Manual, it says to bleed the slave cylinder first, then bleed the clutch piping connector last (the bleeder on the passenger side fender well)
This is how I bleed mine and had no problem, but as long as you get all of the air out of the system thats all that counts. And yes speed bleeders are your friend.
Old 06-11-2005 | 06:20 PM
Thanks Guys For all the help now I can come out to the meets when you have them Btw what day do you guys all get together ? So I can come to thanks
Z_TankIsFull
Old 06-11-2005 | 08:13 PM
CanyonCarver's Avatar
Jack Of All Trades
Z_TankIsFull
There's a meet?.............. Where? ..............When? I wanna go.....
Where do you live ztznk?
Old 06-13-2005 | 07:22 PM
I Live in vegas and I was told the vegas guys meet up on fridays just to get together and kick it
Z_TankIsFull
Old 06-13-2005 | 08:58 PM
bardabe's Avatar
Bad Speller
Z_TankIsFull
you might wanna turn to Dr, Buddah for that. I believe he's the group leader up there.
Old 06-15-2005 | 01:01 PM
ok thanks
Z_TankIsFul
g.k
04-15-2013 09:50 PM
LikeZcars
02-24-2013 06:41 PM
iluvJDM
04-12-2006 07:55 PM
bLackout
25
01-24-2006 11:25 PM
Z_TankIsFull
06-16-2005 10:53 AM
Quick Reply: Noobie Clutch Question
