O2 sensors
O2 sensors
How hard is it to change them because i cant even see them..i can feel them but only barely see them...anyone have any special ways that i am not figuring out..or am i just letting the car be more smarterer than I?
most recommend a O2 tool available at your local parts store for about $10-12. The passenger side is more accessible if you remove the battery. Practice calisthentics for the driver side. Many find it necessary to use a rachet with a couple of swivel joints to accomplish the job.
(Then there are those of us with an additional 2 after the cats (OBD II). And that's a different story totally.)
O2 Wrecnches are basically pipe wrecchs..all the do is keep you from stipping the bolts. The tool lightspeed is referring to looks like a deep well socket, with a section cut out on the side like an arch way of a door. This cut out is so that you dont mess the wires up on the O2 sensor. If you dont understand what I mean, you will once u get the tool. It will make life much easier.
