oil burning out driver side exhaust pipes
Guest
Posts: n/a
got new turbos new long block but the same problem as before on 90 tt.Blue smoke (indicating oil) from the driver side pipes.Engine oil level regularly is low.This only occurs at idle after the engine is warm. Any help out there is a big help-thanks and good day to you-Marlon.
Ring blowby? Blown seal somewhere? Obviously Oil is getting into the combustion chamber somehow. Who built your new engine? Mabe you should take it back and have them check it. I'd hate to spend that kind of money and still have a problem with the engine. You do have some kind of warranty, right?
Twin_Turbo_300z
07-20-2010 01:38 PM
