oil pressure and temp
hey guys i have a problem it seems like i dont have any oil pressure in my 1990 TT. upon start up the pressure gauge works fine then when u push the clutch in it drops to 0. as i push the gas pedal it climbs back up to about 60psi then drops again when clutch is pushed in. after a few moments of that the needle stays at 0psi. lastly im getting a lot of heat in my in the interior along the shifter center console. is it my transmission or ac condensor. help im new to the game and its my first TT. maybe its my mods i have mild racing cams 1 piece driveshaft, 555cc fuel injectors test pipes down pipes 3 inch exhaust and boosting at 14psi low boost high boost 18psi
