Overheating TT: Electric fan or headgasket?
Old 04-17-2004 | 01:09 AM
Riz Z Speed's Avatar
Administrative Brown Guy
Well you could go either way with this one. If you go with the proper sized electric fan, you free up hp by getting rid of the rotational mass that is the stock fan. But most electric fans (unless you use two) won't measure up to the stock one. You're going to want to get close to the stock cfm output which is about 3700 or so. If you can fit two electric fans in there that can combine to close to that number you should be fine.
Or go back to the stock fan by fixing the fan clutch and keep the car cool.
Old 04-19-2004 | 10:52 PM
91zxtt's Avatar
If you have coolant leaking into the oil, then your oil should have a milky consistency to it and it should froth up (kind of like milk). Check your compression. Are you getting any white smoke out of the exhaust, or does the exhaust smell sweet? Those Z dipsticks are useless. It's almost impossible to read them accurately.
Monkies
02-07-2011 03:03 PM
duowing
10-15-2007 03:39 PM
HybridS130
09-06-2006 03:33 PM
Skip81ZX
03-25-2002 03:24 AM
