Question about '96 300z NA Exhaust
Hello all!
New to the boards here, and pretty new to Z's. I have a friend who got me hooked and I am looking at getting a '96 300zx NA 2+0.
Before I make my purchase, I wanted to ask people who are more informed than I am. When I look at exhaust systems for the Z, most, including GReddy, show exhaust systems for 1990-1995, and exclude the '96. This goes for Turbo and non-turbo. Am I going to be unable to get a good exhaust for this year, or do they just exclude it from the list because there are so few out there?
Basically, will something like a GReddy EVO 2 be compatible with the '96? Any thoughts? Thank you!
A cat back system will work I believe
96 marked the implementation of OBD II.
I'd get an earlier model Z if it was me, simply because they have slightly more power (with OBDII Nissan got rid of VTC) and also they are easier to modify.
Ah, again, a thread that I can respond to with confidence.
I have a '96 and love it. If you get one, be prepared to be someone, er, different. I have found very few pockets of '96-specific wisdom, and much of my understanding has come through trial and error. (I'll pontificate later if you actually get yours.) I bought mine to have a car that would easily pass emissions - or at least be able to warn me that it won't. It does that well. Again, I can elaborate on OBDII if you get yours.
To specifically address the EXHAUST QUESTION... Yes, the '96 is DIFFERENT from all other years. Nissan chose to reverse the output flanges of the catalytic converters, causing "other" cat backs to NOT fit.
You will need to replace the cats as well to get non-96 cat backs to fit. BUT then you run into the fact that OBD-II cats need FOUR bungs for O2 sensors. Either way you go, it's custom all the way, baby!
Let me know if you get it ...
Hmm- I like loud, but not THAT loud.
I've learned that custom usually equals more expensive... and more hassle. The car looks to be in great condition. If I do end up getting it, I will get a full diag run on it to see how it looks. The body is in excellent condition. Here's a link:
http://www.autotrader.com/fyc/vdp.js...or=&cardist=12
Ok, so, other than the exhaust, there's not a whole ton that won't go on as normal, right? hehe. You've all been a great help so far, thank you.
SolidSnake, be prepared for lots to be "same, but just a bit different." The ECU upgrade options are limited (only on and that is not all that good), there are about 50% more sensors, the exhaust it different, the car is heavier and slower than most (you will continually be reminded of that when you ask performance-related questions), Data logging software doesn't work, etc, etc, etc. Again, I got precisely what I was looking for, which in the end differs from most Z drivers. Mine is really a unicorn, in that I have a 2+2 as well.
I have done a good bit of work to mine, and getting parts has for the most part been a snap. Pop charger, headers, underdrive pulleys, one-piece drive shaft, ceramic pads, short shift kit, flywheels, racing clutch - they all bolted right up. The exhaust has been a real chore. But given the number of postings on that topic, I am not alone.
Almost 90k miles for a 96 is on the border, mine has only 65k - low mileage ones do exist. I am concerned that the price it so low. Most 96's that are cream puffs command prices between 13k-18k. Drive it and let it really warm up. Then drive it some more. Watch that it idles smoothly when hot, and that there are no hesitations or studders in the mid rpms (2000-3500). Those kind of problems can drive you nuts chasing down, and ones that will most quickly solicite the "oh, yours is a 96?!?, ahhh...." comments. :-)
BTW - Welcome. This is a great board. The advice/comments are typically very good. Warning - say something stupid and "they guys" will rag on you! (I've learned the hard way!)
Man... well I have my work cut out for me.
NA's don't have PSI meters do they? When I went and looked at the car, it had one. Mean anything special? Should I be on the lookout even more? /shrug. Goin' in on Monday and expecting to give it a thorough workout to see how it runs! Thanks for the tips Lightspeed. I'm sure I'll ask some stupid questions. Rag away! How else do ya learn? =)
[QUOTE=SolidSnake]
QUOTE]
BTW - this car is advertized with a "tilt wheel". Uh... the Z didn't have tilt.
QUOTE]
Yeah, that does seem like a rather high price to pay for the mileage, non-turbo, and color! Even though it's the rarest year, for that price, you can shop around and find a slightly older (but lower mileage) TWIN TURBO Z. I did, and it turned out great for me!
Lightspeed...you said the exhaust has been a real pain because the flange bolts are reversed. Couldn't you just have someone cut the flanges off, turn them, then reweld them? I personally couldn't do it, but any muffler should be able to do it for cheap. Just my .02.
A saw that Stillen sells an ECU upgrade for the '96 now. It is of course JWT, but it's better than nothing.
I have heard many people say, Avoid the '96 because of the OBD-II", but I don't know why the ODB II is so bad.
Is that really such a high price? Take a look at all of the Z's in 98166 zip code on autotrader.com Maybe it's just a bad time to try to find one. Most of the mileage is higher than the '96. I'm also concerned about 2 things with the TT: Upkeep, and insurance.
I'd love to have a TT, but I don't think I'd have the money to try and replace the turbos if they went out. Most of the turbos have fairly high mileage.
What do you guys think about this one:
http://edmunds.autotrader.com/fyc/vd...or=&cardist=16
Originally Posted by 91zxtt
...saw that Stillen sells an ECU upgrade for the '96 now. It is of course JWT...
...I have heard many people say, Avoid the '96 because of the OBD-II", but I don't know why the ODB II is so bad...
That is your decision! :-D
LOL well yeah! But from everything I'm seeing out there, it doesn't look very highly priced. Most of the models are even higher mileage than that! I'm going to test drive the '96 today with a friend who has a '91 NA. I'll let you know how that goes, and if I can go down on the price at all. I still wish the exhaust wasn't such a problem... although I have seen my friend struggle with his '91 to try to pass emissions with his GReddy Evo
I doubt that the exhaust system has anything to do with his ability to pass emissions.... keep us posted!
As far as that chip goes,...I had no idea that Stillen sold the Jet ECU for the '96. The '90-'95 ecu upgradessold by Stillen is JWT. I don't know how the Jet prgram is on the Z, but I've read that the one they make for my truck is garbage.
Actually I'm not all that disappointed with the Jet. They just adjusted the fuel and timing maps when the computer goes open loop. When I upgrade my exhaust I'll let you know what I get out of the engine. Right now I am running just above stock, but with a couple of other mods.
