So you guys like clutches?
whatcha putting down for power?
Cause the stock clutch for the TT is pretty decent, if you are putting down less than 380 whp then the stock one will run well as long as you don't do a bunch of high rev starts.
I've tried the 6 puck clutch XTD an it was a bit loud and squealed a bit after 10k miles.
I've also tried the dual plate clutch and its fine if not a bit touchy, I still stall out every now and then due to the small sweet spot.
Sorry didn't notice you were in a NA until after I posted.
Exedy Stage 1 Organic clutch for the non-turbos is probably your best bet at around 320$. The OEM one is about 220$
