some clutch issues
Old 06-06-2009 | 08:08 AM
z32Burns's Avatar
some clutch issues
I've got a slight problem right now.. my clutch had went out on me before i came back to iraq, so i ordered a spec clutch and flywheel for replacement. the 2 parts are for the 90 n/a.. i had it all put in by my mechanic and it all goes good, up until you try and give it alot of power, then it seems to slip. would the spec clutch and flywheel not be a good combo for everything else being stock and i should have just gone with the original parts or what. also im pretty sure the synchros are bad cause its grinding when i go into 2nd when i get on it, but if i relax and shift then theres nothing. any ideas?
Old 06-09-2009 | 05:26 AM
KasbeKZ's Avatar
Pr0n Addict
your mechanic probably got oil or grease on the friction surfaces.
what do you mean by spec? you mean aftermarket or OEM?
Old 06-09-2009 | 03:41 PM
z32Burns's Avatar
ok ill check into that..
and by Spec, i was pertaining to the aftermarket brand
jr84'300zx
12-23-2013 08:47 AM
7d82adz
07-05-2013 07:09 PM
SwitchAZ
06-04-2012 02:35 PM
Wishihadahonda
12-08-2009 12:27 AM
colin_barnes
07-23-2006 09:58 PM
