some performance tips?
Old 06-16-2006 | 07:30 PM
STRANGER_753's Avatar
i have a 94 300zx tt and i would like to know what kind of mods should i do first to the car, but at the same time get so good hp #'s out of it.
already installed
1.stage 2 clutch
2.pipping hks high power
and took off 2 of the converters
3.and hks intake.
ps
how many converters does this car have? i heard 4
Old 06-17-2006 | 02:59 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
You have two precats and two cats. If you removed the two cats, you still have precats.
This post should be in the Performance/Technical section.
Your next mod should be a JWT or Ash ECU with boost jets. Good for about 60 horsepower provided the boost jets actually net you an additional 5-6psi (ever car is different).
By the way, search "stage chart" to see the order of which you should do performance modifications.
Old 06-17-2006 | 07:10 PM
Riz Z Speed's Avatar
Administrative Brown Guy
moved to 300ZX (Z32) Performance / Technical
agreed. I'd like to think i've stickied most of the commonly asked questions or at least the answers to said questions.
Old 06-19-2006 | 12:16 PM
Thanks Guys
Old 06-28-2006 | 08:53 PM
91zxtt's Avatar
Come on Rizz,...you should know better than that. It doesn't matter what you write,...people need to read it.
Old 06-29-2006 | 01:57 PM
silvrhand's Avatar
Snazzy Title
Ok,
I'm probably gonna get flamed for this but this is my opinion. The JWT ecu runs richer and is "less" borderline tuned than the AshECU. I would highly suggest going the Chip/Boost Controller/AFC at the same time, I would also suggest the JWT ECU. Put everything on and leave the boost STOCK, get to a dyno with a wideband O2 and tune it up slowly while watching your A/F ratio and adjusting as normal. This will provide the best setup for YOUR car, which can be different depending on age/condition/environment/etc/etc/etc.
The JWT ecu is known to run rich, it WILL produce less power but will be a SAFER tolerance for lean conditions. Being too rich is a problem, but it's not going to detonate your engine, going LEAN is VERY VERY BAD. That's the reason for the AFC and dyno time for PROPER tuning.
/em prepares for the flame war.
Of course this is totally my opinion and experience, you are welcome to use it or do what you want with your own car!
Old 06-29-2006 | 02:00 PM
silvrhand's Avatar
Snazzy Title
I officially went with the emanage blue + Greddy Profec E01 and came out with 360+rwhp, and over 410 torque.
Old 06-29-2006 | 04:28 PM
Yeah like the old saying goes, you can lead a horse to water but you can't make him drink.
Guess i'm just too optimistic?
ThermalWake
06-18-2009 11:42 AM
d33zdrama
01-07-2009 01:59 PM
DATSUNSOCAL
01-11-2007 05:07 PM
Z Car Barbie
16
09-19-2006 10:12 PM
jr260z
03-07-2002 05:28 AM
Quick Reply: some performance tips?
