starter issues
starter issues
ever since i got this car, it occasionally takes me a few turns of the key to get the starter to go. then the starter works great. well finally it got to a point where i couldn't start it a couple days ago (turned the key about 20 times with nothing. accessories all came on just fine). i finally got a chance to check it out and i checked the ignition fuses and gave it another go, and after 3 or 4 turns, it started right up. i moved it onto ramps so i could check the starter out, cut it off, tried again, and it worked again. so now i have a problem. i have nothing to test, because it works. it won't work forever, and may leave me stranded next time i take it out. whenever i turn the key and the starter doesn't turn, i never get a click. i'm thinking the solenoid?
just to close up this topic for record's sake:
i replaced the relay, problem completely fixed. and i didn't spend $70 on a new one from courtesy. i got one from advanced auto for $17. and it's great. so i'll see how long it holds up. probably longer than i'll have the car so it's all good!
El_Colombiano
01-18-2013 04:36 PM
vvillium3
08-21-2005 10:06 AM
AlongCamePeter
09-12-2004 07:20 PM
