test pipes on n/a????
Old 01-22-2004 | 05:14 PM
typeaproduction's Avatar
i have read that you shouldnt use test pipes on a n/a because of the pressure that would come back into the engine, .... i saw these SZ Test Pipes at
http://conceptzperformance.com/Cart/...24.197.127.140
are these bad for the n/a... this is the only site ive seen with test pipes for n/a model. im wanting to put an exhaust system and find it cheaper to buy the muffler and pipes seperate... brain storming here.... so what about those test pipes??? thanks for anyones info
Old 01-22-2004 | 07:29 PM
Z_WRECKER's Avatar
since n/a is not turbocharged (duh) the back pressure is important to keep the off the line speed, but if you have an x bent and a decent muffler you should be ok. it will also make your car louder, not to mention it wont pass the emmision test
Old 01-22-2004 | 07:40 PM
emo236's Avatar
confuzed member
You will lose performance with those. It will make your car louder, but will take away all back pressure. turbo motors want their exhaust as free flowing as possible because it allows the turbine to spin more freely, but in an NA motor...the motor needs some back pressure and it will hurt the performance if you open the exhaust too much.
Old 01-22-2004 | 08:11 PM
Z_WRECKER's Avatar
but emo will he gain some top speed with that??
Old 01-22-2004 | 08:17 PM
91zxtt's Avatar
Any top speed he MAY gain would not make up for the bottom end he WILL lose. With the N/A, after you've replaced the Cat-Back system, there's not a whole lot you can do to increase horsepower significantly in the exhaust. It would make more sense to get an exhaust manifold instead of the test pipe. It's more work, but more worth it.
Old 01-22-2004 | 08:28 PM
Z_WRECKER's Avatar
once again good point good work
Old 01-22-2004 | 09:32 PM
91zxtt's Avatar
Thanks for your support. What kind of dog is Z?
Old 01-23-2004 | 02:21 AM
emo236's Avatar
confuzed member
Didn't know that. Sounds logical enough however.
Old 01-23-2004 | 09:08 AM
emo236's Avatar
confuzed member
Yep, that is another option and a rather economical option. It's common to gut your cats. If you do have to worry about emmissions...maybe a test pipe that you can take in and out might be the way to go....
Old 01-23-2004 | 09:28 AM
emo236's Avatar
confuzed member
Yea..it sounds logical to me. If you want to direct the air even more...you could remove your cat and put in some exhaust piping (rahter inexpensive)...that is if you have some welding experience....basically make your own test pipe. But gutted cats do pretty well for being free ninety free. Did you feel a gain from doing this? Just wondering.
Old 01-23-2004 | 08:31 PM
Z_WRECKER's Avatar
so test pipes for an n/a good or bad.....
and Z is a 11 month old female rottweiler, who absolutely loves to ride in my z. she won't let anyone come close to my z. and since i took the stock seats out she just chills on the passenger side one all day
Old 01-24-2004 | 12:00 PM
emo236's Avatar
confuzed member
Cut the top off of it??! what was he thinking?! But, Rizz, where are you on this one. Are test pipes good for an NA?
Old 01-24-2004 | 09:43 PM
Z_WRECKER's Avatar
how do you cut a top off a Z....hard time imaginig that....did he think he would make it a convertible?
Old 01-25-2004 | 01:54 PM
Riz Z Speed's Avatar
Administrative Brown Guy
freer flow is freer flow. If you have emissions in your state, I would recommend hi-flow cats and pipes.
Old 01-25-2004 | 10:28 PM
Z_WRECKER's Avatar
thanx rizz.... i'll just wait untill i have enough cash to do the swap
Old 01-26-2004 | 10:40 AM
Z_WRECKER's Avatar
a mudder out of Z???? what was he thinking....save that Z from him, or whatever is left of it...can you post a picture of it for us, bc i would like to see that
Old 01-26-2004 | 10:21 PM
Z_WRECKER's Avatar
good deal man ,great deal, hell bring him a 6 pack you might get it for $150
Old 01-27-2004 | 01:00 PM
91zxtt's Avatar
You may need to buy a keg-erator for the amount of work you're going to put into that thing. Car repairs always go better with beer. Come to think of it, most things go better with beer.
Old 01-27-2004 | 02:04 PM
Z_WRECKER's Avatar
hahahaha...good one 91zxtt
Old 01-27-2004 | 03:09 PM
91zxtt's Avatar
Did I mention I like beer? Back to the original topic though, With Test pipes, how much could I expect to see out of my car? Since I'm in CA, I'll need the hi-flow cats with it. I'm guessing 15-20 HP. Anyone have info on this?
