Timing belt change
Timing belt change
hey guys, had a few questions on doing a timing belt (new to this) and was hoping for some advice.. Im getting a kit from z1 motorspots {oem 60k kit}
im assuming i should also get both upper and lower pulleys, and the full oem belt set..
What i was wondering is that sense im getting a AMS Light weight underdrive crank pulley should i get the overdrive water pump?
In addition the the pull down box is states under AMS Accessory Pulleys (complete set), what im asking is what exactly is the complete set of AMS accessory pulleys? does it include ac/pws...etc.. but in AMS standards?
thankyou in advace for the help...
You shouldnt attempt a timing belt at all if youre "new to this." If you mess it up your motors toast.
The AMS set should be the power steering, water pump, alternator and crank (underdrive pulley). Change them when youre doing the timing belt or have someone do it for you.
Really wouldnt attempt this sort of job if youre new to it though.
hey appreciate the feedback thank you, also don't worry im not doing it mainly just standing along side learning. but i do have to order parts i looked at unorthodox pulleys.. unfortunately i dont have the money and the the set z1 motorsports seems to be the best route for me right now i wish i could take ur advice i just need a water pump and everything else so i can get back on the road. Thank You everyone
We have a saying... it goes "buy cheap, buy twice." How much money do you think you'll be saving when you have to replace your cheaply purchased stuff that starts to cause problems with the stuff you should've bought in the first place?
Assuming your cheap parts don't cause issues with other components (a misaligned water pump pulley, as AMS has been show to be, will cause wear on the bearings of your water pump), you'll spend $X on the cheaper part, and then $Y on the better part later on.
Since both X and Y > 0,
X + Y > Y
Thus, buying the better part in the first place actually ends up costing less.
In actuality, let the other parts that wear out because of the cheaper (shitty) part cost $Z. Surely X + Y + Z > Y, when you buy the shitty part, its replacement, and then fix the things that break because you didn't take our advice.
Enjoy your car. If you can't afford to mod it properly, you're not going to get to drive it much. And when you do, it won't be as enjoyable.
ha alright thanks for the advice i was just going to keep it stock i wasn't going to get the ams crank without the water pump.... everything else aside , you all should be pleased i fell into money and im getting the ur crank and water pump.
Frodz
01-01-2012 09:04 AM
CanyonCarver
12
05-16-2005 12:57 PM
