Tire Shimmy
Guest
Posts: n/a
I would first jack up the front end and grasp the tire with both hands. (top and bottom) Shake up and down to see if there's play...if so it's a wheel bearing. Shaking from side to side indicates a tie rod problem. Also check the ball joints and any bushings on the car. Do those visual first before going to the shop. The shop can check your tire's balance and alignment.
Guys if I missed something fill in, please. Or if I said something wrong...correct me. Thanks.
Chris
Chris
