TT Swap buying guide?
Ok before you go " another TT swap" hear me out. I have completely finished my suspension and brake upgrades on my NA. I have a detailed plan and I fully understand what has to be done. I'm not very partial to the use of used parts, I much rather buy all new but that also be very cost inefficient. So the question is what parts could I go used without a lot of fear of things going wrong later down the road. My power goals aren't very extravagant but a turbo upgrade will be automatic. For now I plan
IPP stage II rebuild - solely because I dont trust jdm engine
z1 600r turbo kit
z1 sidemount IC
jwt pop charger
underdrive pullies
Howe TT radiator w/ electric fan
stillen oil cooler
555 injectors
ms manifolds
5 bolt dp's
I don't really have a particular hp goal. I want my Z to serve 3 functions. In order a decent autocross car, a street car with as minimal lag as possible, and third good looks. Thanks for you input and sorry for the long post.
z1 600r turbo kit
z1 sidemount IC
jwt pop charger
underdrive pullies
stillen oil cooler
555 injectors
ms manifolds
5 bolt dp's
Oil cooler kti with oil lines, Intercooler pipe kit. TT Fuel pump or a walbro 255. tt clutch, flywheel and take about 1/8th of an inch out of the N/A tranny. get spacers for the starter. polyurethane motor mounts and tranny mounts, 3" exhaust. divirced flange DP. boost controler,Ashspec ECU, New harness, SAFC-II for finetuneing the ECU, 1 piece driveshaft, ..... etc.etc.etc...
NismoPick
06-21-2015 01:58 AM
NismoPick
05-27-2015 12:46 AM
