Turbo timer, please help!
Guest
Posts: n/a
Just installed greddy turbo timer with harness. Didnt install ebrake or speedo wire but the greddy website says optional. When i turn the key to auxiliary the timer shows "off" really quickly then nothing. When i start the car and try to turn it on it does nothing. The ground is going to sanded bare metal so im ok there, but what am i doing wrong? Should i try a different ground? I harnessed to the correct wires i believe. What would cause this to happen. There is no "If this happens, then" in the greddy manual so im in the dark. Please help.
Guest
Posts: n/a
Re: Turbo timer, please help!
i would just go back and re check everything, did you buy the optional harness for it? or did you splice into the wires of the harness. maybe the turbo timer is fault also!! b/c its a very simple procedure, one ground, and the wires with the harness, which is a simple procedure. but hey, we all make stupid mistakes, i know i do all the time, otherwise i would try to get another one and test that!
1990 TT (Charcoal)
1990 TT (Charcoal)
blkthghts
08-04-2003 11:52 PM
