Turbos
Turbos
Ok i have a question about turbo's for the z..I heard that the turbo's on the z's are made by garret..so i also heard that mitsubishi eclipse turbo's would bolt right on..is this true? if so would it be an upgrade or are the eclipse turbo's the same?
to be honest, i have heard about the stock 2nd gen eclipse turbo would be a good upgrade to a stock TT...my friend who is a dsm freak says that minor modifications would have to be done...as far as $$$ is concerned...stock dsm turbos are selling bellow $100 in dsm boards w/ low miles on them...so interesting question as i would like to know the answer from our z gurus..
The throttle body upgrade you mentioned is for the Z31, not the Z32. I've never seen anyone put Eclipse turbos on a Z32. I personally wouldn't do it because I don't like Mitsubishi's. If you really want to upgrade, then go with JWT sport 500's or 600's.
well i would like to get the JWT turbos but $ is an issue right now..and my oil lines have been leaking so my turbos arent getting enough oil and they are going bad..they sound dry almost like there is sand in them haha..but anyways i figured i would have to replace them soon so i would look for something inexpensive and a little better so i just figured i would ask you guys what you thought..so i appreciate the help, thanks alot
I've seen the Eclipse turbos on the TT.
Since the Mitsu is a 2.0 motor, the TT is basically two 1.5's put together, the Mitsu turbos are quite a bit of an upgrade. If you can do the required mods to make them fit/work, then yes, it's doable.
2nd on the throttle body mod, it's for the Z31, not the Z32.
remember eclipse turbos cost less than any turbokits and all u gotta spend is money on fabrications to make it work...im just wondering why someone hasnt made a turbo kit that uses the eclipse turbo..i mean it can make more power than the stock TT turbos and still be very affordable.....maybe below $1500????
ok so i am about to buy my turbo's...but i have another question..Does anyone know if the 1st gen eclipse turbo's would fit? the 14B turbo's? I need to know fast cuz i dont know how long the offer will stand
Originally Posted by CanyonCarver
You need to know the configuration of the flange on your existing exhaust manifold (t28?) and whether or not the mitsui turbos are the same. if not you'll need to make some adapter plates. ie: I've made adapter plates to mount t3 turbos to exhaust manifolds with a t25 configuration. The only way that I could tell is to measure the hole patterns in both.
Hmm..I saw on a web site (which of cource i dont remember which one) but i saw that the Z's have Garrett T22's..it might have been wrong though i dont know..I just know that the T25s should be a pretty good upgrade and the 14B's are better turbos..we will just see cuz i bought the 14B's anyway cuz i got em for a price that i couldn't say no to..lol..worst case, i sell em and buy something different..no big deal
