Using used engine .. Best way to chain the engine?
What is the best way to chain the engine to drop it in? I just bought a used engine with 54000 on it and i don't know what hook the chains on. Would it damage anything to hook up on the plenum? I'm using a cherry picker hoist to drop it in. Any ideas would be great. Thanks
There are two common methods - one uses the bolts that go into the sides of the plenum (they originally hold a bracket in place), an alternative is to use a top plenum bolt and one of the top trans bolt holes.
Best method is with the RameyZ engine sling... uses top plenum bolts.
I just did this last week, my hook up worked pretty well.
On the driver side of the motor I had a singer on the side where the brake booster vacuum line goes into and on the passenger side i had the slinger on top of the plenum towards the back where its kind of just a cap screwed into the plenum behind the balance bar.
I tried the brackets and it wound up snapping off the motor.
I also tried the top plenum bolts but didnt feel safe at all with them.
smokingzcar
12-05-2002 08:57 AM
