View Poll Results: How much is a vg33 bottom end worth ?
50 - 150
0%
151 - 250
25.00%
251 - 350
25.00%
351 - 450
0%
451 +
50.00%
Voters: 4. You may not vote on this poll
VG33DE build
Old 07-15-2006 | 09:45 PM
rxKaffee's Avatar
VG33DE build
I'm considering building up a VG33DE using the vg33e's bottom and heads from the vg30de.
I was wondering what you guys think is fair market price for a VG33E minus the heads.
Old 07-15-2006 | 10:25 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
For that purpose... $0.00; but that's just my opinion.
Old 07-16-2006 | 12:27 AM
rxKaffee's Avatar
Why is that?
Old 07-16-2006 | 05:59 AM
CanyonCarver's Avatar
Jack Of All Trades
Originally Posted by rxKaffee
Why is that?
Because he thinks you should only do a vg30dett swap and nothing else.
There were relatively few vg33e's built, so I voted $451+. They went away when the vq35 came out. You might get lucky and find one in a junk yard. Here's a listi of the the vehicles that I could find with the vg33.
96-00 pathfinder vg33e
99-02 quest vg33e
00-03 frontier vg33e
01-04 xterra vg33e
01-04 frontier vg33er
Old 07-16-2006 | 08:48 AM
silvrhand's Avatar
Snazzy Title
why cause yourself extra pain by using a VG33 bottom end, why not just use the VG30 and be able to find the pistons and stuff that you'll want in a buildup?
Old 07-16-2006 | 04:17 PM
rxKaffee's Avatar
The VG33 block can be bored out more than the VG30 due to the small amount of extra metal it has on it.
Old 07-16-2006 | 05:15 PM
Jack Of All Trades
I'm kind of planning the same build to some extent. Here is some info you might find interesting. --->>> vg30 = vg33. The main difference between the vg30 & vg33 is the diff between 87mm & 91mm pistons. People keep telling me that you can't bore the vg30 for 91mm pistons. I just say I'll install liners if I have to.
Old 07-16-2006 | 08:27 PM
bardabe's Avatar
Bad Speller
yeah it;s bullshit you cna bore out a VG to 91mm no problem. if the block is the same. shouldn;t you jus tbe able to Re-Sleeve the motor??? cause that;s what some guy did for his SR. it was insane. when Ifind the link I'll let you guys know. RB25 Pistons on SR 20... yeah U heard me SR25
Old 07-17-2006 | 11:57 PM
rxKaffee's Avatar
After some further research, it appears that I might have been slightly un-informed about that statement.
It seems that the difference in bore-ability is not between the VG33E and VG30DE, but between the VG33E and VG30E. Or between the VG30DE and the VG30E you could put it I guess.
It still serves its purpose for me though and saves the cost of machine shop boreing the block.
HOWEVER; I believe I've allowed my thread to stray from its original topic. And for this I apologize. I intended this not to discuss the merits of what I intend to do with this block, only what you might think its fair market value is. I do appreciate everyone's contributions of information regarding these engines though! I learn something new about the VG every time I look into it.
Old 07-18-2006 | 01:15 PM
Jack Of All Trades
I don't think you strayed too far off topic. I tried to answer your question and then provide a little insight. If there is any additional information that you come across regarding vg30 --> vg33 compatibility please share it. One thing I've wondered myself is if the holes exist in the vg33 block for the t-belt tensioner & idler pullies for the twin cam heads.
Here's another interesting link that you might find helpful --->>> ENGINE MATRIX
Old 07-18-2006 | 03:02 PM
VG__DE and VG__E parts are not interchangeable from what I've seen and read. So if you were thinking of using a VG33E block with VG30DE heads, it's not going to work (same with trying to use a VG33E crank in a VG30DE block, etc etc etc).
Old 07-18-2006 | 03:33 PM
silvrhand's Avatar
Snazzy Title
And?
The amount of power you are going to gain from that isn't going to be worth the pain/process involved? Why not just go with the VG30 block and be done? The VG30 can make extreme amount of power without having to bore it. If you are doing a NA buildup.. I'll stop here as again it's not worth the investment unless you are just trying to prove a point and have money to burn.
Old 07-18-2006 | 04:22 PM
rxKaffee's Avatar
From what I read the only difficulty is having to slightly reshape a water passage thats offset a little.
Old 07-18-2006 | 04:24 PM
rxKaffee's Avatar
And?
If a little dremeling on a water passage is all I have to do to get a VG33 bottom end to fit to some DOHC heads, thats a cheap upgrade.
It looks like its going to cost more to buy a VG30DE bottom end than the VG33.
Old 07-18-2006 | 06:07 PM
Jack Of All Trades
And?
I don't see anywhere where
the poster said he's doing an n/a build-up, so it's not an n/a --> tt comparo. Still a vg33dett > vg30dett & vg33de > vg30de. If you look at h.p./litre and the .3 litre being a 10% increase...... it can be significant. Plus, if your doing a build with new forged pistons, the cost difference between 88mm & 91mm pistons is nill. If your doing a build with new forged pistons, the cost difference between boring the cylinders for 88mm & 91mm pistons is minimal. Maybe two more passes per cylinder with the boring head.
vg30 & vg33 cranks are the same.
Old 07-22-2006 | 03:34 PM
rxKaffee's Avatar
Yea, the only part of the crank that differs is the snout. I could either machine the vg33 crank snout or put in a vg30 crank.
Old 07-22-2006 | 06:47 PM
silvrhand's Avatar
Snazzy Title
Again,
Why go some route where you are going to have to fab the work yourself, I mean the VG30DETT combo is easy to get 350+ rwhp from even the stock turbo's.
Do you really plan on putting more than 450/500 rwhp down? If so then you may want to think about a buildup, if not then just go with the VG30DETT, with some new turbo's, injectors, and exhaust manifolds. You'll have more problems trying to keep it on the ground.
*IF* you are trying to do something unique and show stopper then there really isn't much info on VG33DE bottom + VG30DETT buildup good luck and document it for everyone else.
madigity
10-09-2022 03:22 PM
1977280Z
07-23-2014 02:38 PM
ricksilvia
05-25-2014 06:57 PM
Hendoxo
05-21-2014 05:56 PM
bardabe
10-18-2005 07:35 PM
Quick Reply: VG33DE build
