Water leak.
Water leak.
After I drive, when i get out of the car, there is water leaking from the engine on the passenger side. towards the back middle. I can' t tell where it's coming from. It doesn't continue to leak, only for a few minutes, it drops after i park after driving. I'm hoping that it's just condensation on something(maybe AC condenser). Could it be something else that might be dangerous? The car is a 91 TT.
Are you running the A/C?
If you are, then more than likely it is (condensation). Besides nothing in the car should be straight water. If it was coolant, it'd be green. If it was power steering, brake fluid, or oil, you'd be able to tell.
d33zdrama
14
03-03-2012 06:15 PM
