water pump
According to alldata for a 93 NA:
drain coolant, remove undercover, radiator, drive belts, cooling fan & coupling, water inlet & outlet, crank pulley, and timing belt cover
Remove water pump
install in reverse
there may be shortcuts, but I couldn't tell you.
Remove water pump
install in reverse
