Will 15inches clear a tranny drop?
Hey everyone im pretty much new to the z32 scene and DIY in general, i was wondering if i can drop the 5spd transmission to change my clutch at this height.
My car is currently on jackstands at about 15 1/2 inches high.
Ive looked around and read that the car needs to be at least 19 inches high for a clutch job. So im wondering if its possible to drop the tranny at 15inches high with a tranny jack.
Welcome to ZDriver!
And no. The bell housing is taller than 15". Unless you like performing dangerous activities that will likely hurt you, I suggest you go buy taller jack stands, or cinder blocks (if jack stands are too pricey for you).
Any suggestions? I just need to change my clutch.
-Get a better / bigger jack.
-Use a secure block of wood atop the jack mount (contact plate)
-Place jack on raised platform
Use some imagination / ingenuity... hopefully this isn't the first time you've jacked up a car before.
LOL, hey i might just use a wood block to get my car up higher. FYI Im using the garage jack points Shown in the FSM.
Driving the car up onto boards is also a trick for lowered cars.
Click: http://z32.wikispaces.com/Jacking+Up+the+Z
