Z32 TT buck at WOT
Old 06-01-2011, 02:17 PM
tt2x2tt's Avatar
Z32 TT buck at WOT
ok i cant figure this out i have a JDM swaped auto(turbo trans) TT z32 @ 13lbs and when im at WOT easing into or just flooring the pedal the car bucks and rpms drop, it does when boost is at 13lbs but not right away just when the rpms are high, other than that it drives fine, no weird noises, no codes, no leaks boost holds, same power it just cuts itself off, before i had this problem my ECU was governed to 120 i could never go past that, but this is completely different, so any thoughts please!
tt2x2tt is offline
Old 06-01-2011, 06:20 PM
Encyclopedic Knowledge
ZLover4Life's Avatar
Could be a sensor issue (TPS or MAS) or a failing fuel pump.
ZLover4Life is offline
awilkie
08-24-2009 09:18 AM
fantomZ
11-15-2002 08:57 PM
Quick Reply: Z32 TT buck at WOT
