350Z (Z33) Forums Dedicated to 2003 + ZCars otherwize known as the Z33's
Anyone Really Know?
Old 03-29-2004 | 10:22 AM
91zxtt's Avatar
It's always a good idea to reset the ECU after installing a MOD. Generally, when you're working on anything electronic in your car, you're 'supposed' to disconnect the battery. I'm guilty of not always doing it. Some have noticed their car runs poorly after installing a MOD when they don't reset the ECU, but notice an improvement after doing so. What you want to do is leave the battery disconnected for 10 minutes, or so. After you reconnect it, take the car out and really hammer the throttle. Take it to redline, or close, in the 1st 3 gears. This will help the ECU recalibrate the air/fuel mixture, which helps it run better.
Old 09-12-2011 | 08:58 PM
350zgt3's Avatar
Leave it alone. If you decide to upgrade ECU go NISMO ECU & just disconnect & reconnect battery. Drive normal at highway speeds. NISTUNE will be your most reliable ECU tune. MINES in JPN does re-flashes & I personally wouldn't get mine done here, be cautious.
-Aviation NASA Electrician Retired
