1979 280zx N/A
1979 280zx N/A
I am parting out the engine bay of my Z. Going with a V8 swap. If you need anything just pm me and we can work out pricing. I will send pictures if needed to verify specific parts. Thank you
I could really use the thermostat housing. If it the temp sending unit, is in good working order. It is the piece on the lower right side of the housing. I can't change mine, and I have a digital dash one in my '82. And it doesn't read the temperature correctly.
UPDATE:
Cold Start Valve-SOLD
Fuel Pump-SOLD
Fuel Damper-SOLD
Fuel Relays-SOLD
All 6 injectors-SOLD
Block-SOLD
Transmission-SOLD
Thermostat-SOLD
Thermostat Housing-SOLD
A/C compressor-$40
A/C condenser-$30
Power Steering Pump-$30
Alternator-$20
Distributor-$30
Radiator-$45
Intake Manifold(Black)-$35
Exhaust Manifold-$35
Ignition Coil-$5
Cylinder Head w/Cam-$60
Cylinder Head w/o Cam-$50
Camshaft-$20
Valve Cover(Black and Green)-$15
Timing Cover-$20
Oil Pump-$15
Timing Chain-$5
Water Pump-$15
Stater-$30
Still have a lot left. Pm me if you need anything.
Fuel Pump-SOLD
Fuel Damper-SOLD
Fuel Relays-SOLD
Block-SOLD
Transmission-SOLD
Thermostat-SOLD
A/C compressor-$40
A/C condenser-$30
Alternator-$20
Distributor-$30
Radiator-$45
Ignition Coil-$5
Camshaft-$20
Timing Cover-$20
Oil Pump-$15
Timing Chain-$5
Water Pump-$15
Stater-$30
